Wheel Bearing Question???
How can you tell if your wheel bearings need to be replaced? Do they transmit any vibrations or resonance or do they produce any sounds. How can I tell?
What is the part number for these?
Thanks in advance!
Very often rear wheel bearings will make a low grind/hum when you take corners kind of hard. Fronts usually kind of whine I think…
If the car’s sitting on the ground, and you can move the wheel by grabbing the top of the tire and pushing/pulling that means either your wheel bearing’s gone, or there are some worn bushings that should be replaced.
