how do you know if my wheel bearings are bad?
Typically you’ll hear noises like groans coming from the wheels, especially in corners.
It’s called runout, your supossed to messure the deflection/ play in the bearing as the wheel rotates, providing that you can’t do that, you can grab the leading edge and the trailing edge of the tire and wiggle it back and forth. If there is ANY play you are way past replacement, If you can actually HEAR a noise… stop driving the car.
Schu
