whats going on guys looking for some help… I’m about to replace all four wheel bearings on my DA and just wanted to ask a question. I recently did a abs delete so I was wondering if it would mater if I bought the wheel bearings for a abs or non-abs model.
Thanks,
Paul
A little common sense goes a long way!
So when you performed the ABS delete did you change the hubs or bearings on the car ?
So how could you possible think you would need to purchase wheel bearings for a non ABS model ?
They are all the same anyway, there is no difference between ABS or non ABS wheel bearings !
No I didn’t change out any of the wheel bearings when I did the abs delete because it wasn’t necessary. And it’s not that I think that I would need the non-abs bearing I just wanted to ask the stupid question because I’m a stupid guy … thanks for the help bossman
Rears are a lot faster than the fronts, just did my left rear this week. Make sure to have an impact screwdriver for the screws in the rotors and a strong impact gun for the axle nuts, everything else is just hand tools.
