anyone know how much gap (between fender and wheel) there is on a stock suspension?
4-5 fingers depending on age (sagging springs).
just lowered my car 1" = 3-3.5 finger gap
thx. i just wanna adjust my height to stock. i cant get on the dyno test because of negative camber, and i dont really have time and money on getting it corrected. so for now, im 4x4 lol.
If you had your alignment done while the car was lowered and you raise the car back up you will need to get the car aligned again. Unless you don’t mind chewing up your tires.
if you lower 1" its more or less okay…just your rear toe will be thrown off unless you have some hidden problems.
got an alignment today and the only thing off was rear toe. (-0.03). Got it aligned and its now 0.10 and .09. Fronts are zeroed (but within spec even before alignment), and have -1.4 deg. camber.
rears have -1 or something but its within factory specs. (Ingalls shim kit)
but i see you’re raising it. You will have to get it re-aligned as stated above.
