Are the 94+ acura integra wheel hub FRONT (Only) changable to our da?
I have two 94+ oem wheel hub assembly i had as part awhile back.
Basically i been having a grinding noise for over 8 months and i knew it was the bearings. I never dealt with it until recently when i started getting knocking sound which could be balljoint and or axle. its on the driver side only.
As i remove the whole assembly to go get it press in a new bearing the machine shop guy showed me the bad. About 1/4 of the hub is slightly faded had roughness which probably tells me why i been getting vibrations or wheel play. This is why Im in need of one fast and no local auto part sells it only special order and on top of that its rear they carry. Acura dealer sells it for $187.
I called acura and the parts department guy couldnt tell me for sure maybe because of the different part number? Maybe the spindle for the axle are different? IDK Can someone please help explain asap. I need my car running by tomorrow so yea
90-93 oem part number
44600-SK7-000 HUB ASSY., FR.
94-2001 oem part number
44600-S04-A00 HUB ASSY., FR.
