Wheel shakes like hell!!
my car drives like total crap… If you floor it the car shifts over to one side really fast… so I figured I had broken motor mounts and I did… 2 of em… but that didnt totally fix the prob… when im on the gas the front end shakes like hell and pulls to the right… but as soon as I let off the gas the car stops shaking and goes in a straight line… what the hell could it be???
have your front end checked, get an alignment if you need it, balance your wheels/tires, and be sure none of your lug nuts are loose on all your wheels
If you’re talking about when you’re lauching, it does this, it could be wheel hop – very common on fwd cars, and if one wheel’s spinning more than the other (no LSD on our cars), that can cause your car to move to the right or left.
I believe the best cure for that would be to check your springs and shocks both front and back.
So if my shocks are blown out then that could be causing it? It doesnt do it when I launch only but every time I just drive… the slower I go the more the wheel moves…
Oh okay… well it could be that your shocks/springs are throwing your alignment out, but either way, I’d agree with Brian that you should get an alignment and see if that fixes it. Also check and see if your wheels are full of mud or something. that can cause a lot of vibration and sometimes make it seem like you need an alignment.
the alignment is fine and the car is never even driven in the rain so theres no mud or anything in the wheels… I just ordered a new set of shocks so hopefully that will cure it…
U MIGHT NEED NEW AXLES…DONT DRIVE WITH BAD AXLES WILLMESS OTHER STUFF UP AND U WILL JUST SNAP ONE AND UR GONNA BE SCREWED FOR TOWING AND ALL THAT CRAP…NEW AXLES… ALMOST GAURUNTEE IT …ID DINT REALLY READ WHAT U GUYS WROTE I JUST HAVE EXPERIENCE
check you tie rods as well
i think it’s the axles. i ran into a similar problem doing the same thing your does.
well jus check it over carefully. like everybody else said, it could be in the suspension.
