Wheel spacers with stock wheels
Looking for anyone who has used spacers on stock GS wheels. I would like to fill in the gap a bit. So just 5mm. With a 5mm spacer, would I need to worry about the stud lengths? I don’t think 5mm would be an issue. Anything more I can see it being a problem. Anyone running 5mm spacers with stock studs? This is a pic of my car. The back actually is a fraction lower than in the pic, it’s just how it is sitting on the un-even gravel.
I ran 5mm spacers for a couple of years with no problems.
Yea, small spacers like that are fine with the stock studs. Worry about nothing and spacer away
it looks good already like that. Where you plan on buying wheel spacers>?
Not sure yet if I will. But considering I’ve read at least one guy on here used Home depot washers, I think something off Ebay would be enough for what I want.
I had 15mm bolt on spacers with GSR blades and it was just perfect. I think you’d be more satisfied with something a little bigger then 5mm.
