Sry if his has been covered b4 but I need help locating it pic would be awesome , also can this be the problem I’m not showing any temp on my gauge , needle would show hot towards the halfway mark then a few minutes later it would be on cold. Also can this be a problem for my poor gas mileage I’m getting ATM ? Thanx for your input
I already sent you the link you need: http://forums.g2ic.com/showthread.php?196564-Engine-Coolant-amp-Oil-Temp-amp-Pressure-Swiches-Sensors-amp-Sending-Units-Explained
You also need to consult your Helms manual, it has diagrams and wiring for all ECT components.
Plenty pictures show up if you google it. http://bit.ly/186nwCN
There’s confusion on this stuff because people don’t specify “switch” vs “sensor” vs “sending unit” so look at the pics then compare to the write up I linked you to. The write up has the info you need, read it till you understand it. If you need clarification then feel free to ask me or better yet, consult your Helms.
thanx colin
