IF I was to machine the PS and AC portions off the pulley, will the balancer still be present?
the balancer is in the middle of the pulley, i had the outer pulley cut off and then the middle one was cut down but not removed, and the rubber was left in
without looking at it right now, I can’t remember, but I believe if you look at the area around the part of the pulley where the alt. belt is, that is where the HB would be
Why not buy a CTR Crankshaft Pulley. It has no Power steering or A/c Pullies incorporated. It’s made by Honda so it should work.
