Where to start troubleshooting
Over the weekend I had a new timing belt put in, new oil pump, water pump, new headgasket, ARP studs and a new intake manifold.
After I took the car for a spin after all that everything was fine, smooth, felt great. I get off the highway to drive home and it starts sputtering in lower gears, feels like it has no pull or power and the exhaust sounds like a mix of fart can and machine gun at the same time.
I popped the hood and it seems there’s a coolant leak from the heater inlet hose coming out of the block. Could it be as simple as that hose needing to be changed and that’ll fix the issue? I didn’t think losing coolant would cause the car to lose power like that. The gauge isn’t showing the engine running hot or cold, it’s on it’s optimal setting.
Any suggestions where to start troubleshooting would be great.
Thanks.
Coz
if there is air in the system it will run rough.
i had a very small leak, and i’d notice rough start ups when water is low.
Ok so that’s what it probably is. Cool, I’ll look to replace that hose, burp the system and hope for the best.
Thanks,
Coz
If it’s bogging, low on power, and making strange exhaust noises it sounds more like a mechanical timing issue. Air in the cooling system or low coolant can cause some idle issues and running rough, but it shouldn’t be a severe problem.
I would pull your valve cover and check mechanical timing first, there’s a good chance that whoever put the belt in didn’t tension it properly and it slipped a couple teeth. Or possibly you need a new tensioner - which should have been replaced when the belt was replaced.
Focus on your coolant leak after you know your timing is OK. Otherwise you could end up with a bent valve.
Thanks for the heads up Colin, I’ll check that first.
Coz
Ok found out what it was… the fuel regulator cracked because when the intake manifold was put on it had to be bent to fit with the new manifold.
The inlet hose is fixed, the timing looks good, so at least now I know where the issue is.
Thanks.
Coz
