Where's is the ignition transistor located on a JDM OBD1 PR3 ECU (B16A)
:smiley: Hello Everyone!! I have a question on a very rare PR3 B16A OBD1 ecu (This one is for the JDM XSI if I’m not mistaken, or integra with the B16A engine). I tried to use this ecu on my LS/VTEC but it didn’t fire any spark. The engine did crank though. I’m trying to find out where is the ignition trigering on the ECU located so I can swap them with another PR3 ecu that I have for spare. Since they have the same mother board and number as the non-vtec they should use the same transistor as the vtec. If anyone have pictures of it, it would be even better. Any help will be appreciated!!
Vic
did you download the ecu pinouts spreadsheet in the teg tips? it lists what all the pinouts are for a number of ecu’s. It doesn’t specifically list the obd1 pr3. but it does list the obd1 pr4 and p61, which, pinout wise should be basically identical in most respects.
Where can I find this pin outs??? I would have to trace them and find the transistor/chip that works them but sometimes it is impossible to do this since other chips are on the way.:frowning:
