which exact bolts I need to mate the housing to the block
Hey guys,
I’m running into a bit of an issue here in my swap. I have everything I need to swap, except for which exact bolts I need to mate the housing to the block. I’ve search UP and DOWN G2, HT, CI, JDMCity, you name it. I’ve even spent days on AcuraAutomotiveParts.org to see if I can determine which bolts I will need for the housing.
The problem is, the diagrams are calling for some odd 16 bellhousing bolts to mate it. Now, I’m looking at the transmission, and I only see 3-4 spots really where it bolts through the bellhousing to block.
Does anybody know which bolts I will need to mate these together?
For reference:
Auto Bellhousing
Manual Bellhousing
I just need a little inside advice from people who have done this. The guy I bought the tranny from threw all his bolts away, and there are no manual civics/integras or anything in the yards right now that haven’t been stripped.
Thanks!
  • Brandon
http://www.acuraoemparts.com/delray/jsp/prddisplay.jsp?inputstate=5&catcgry1=INTEGRA&catcgry2=1993&catcgry3=3DR+LS&catcgry5=ENGINE%2BSUB%2BCORD%2B-%2BCLAMP&ListAll=All&vinsrch=no
#34 (look at quantity needed)
#35 (look at quantity needed)
#53 (look at quantity needed)
#56 (look at quantity needed)
#57 (look at quantity needed)
That is what I could find from a quick search.
[QUOTE=unified112;2259597]http://www.acuraoemparts.com/delray/jsp/prddisplay.jsp?inputstate=5&catcgry1=INTEGRA&catcgry2=1993&catcgry3=3DR+LS&catcgry5=ENGINE%2BSUB%2BCORD%2B-%2BCLAMP&ListAll=All&vinsrch=no
That is what I could find from a quick search.[/QUOTE]
Wow that’s some knowledge! I couldn’t find that overview for the life of me, I guess I wasn’t searching right. So this should be all I need to completely mate the tranny to block? I have those two starter bolts because luckily it was still on the car when I pulled it.
Thanks for the fast reply!
  • Brandon
I don’t recall if that’s all of them or not. Count how many holes your trans has, then you’ll know how many you’re looking for.
My car isn’t accessible at the moment or id glance at it… but this is at least a step in the right direction.
