should i use basic sylvania h3 55w fog lights or should i use the
Silverstar H3 55w Fog Lights?
I’d get the Silverstars. However, if you do, you may run into the “bulbs blow my fuses” situation. Our cars use H3 35w fogs, & many people I’ve talked to (& myself) blow fuses almost immedietly when using 55w. Problem is, 35w are nearly impossible to find here in the states. Get the Raybrig or Stanely ones, as Sylvania doesn’t make 35w ( I checked, cause I ALWAYS use Sylvania bulbs if possible.) :burnout: :manual:
