I have an ls/vtec with the following things done to it. Ijust want to know the best headers I can get for the mods I have and something with some ground clearance becuase I’m pretty low. thanx. (moderatly priced)
-b16a1 head
-3 angle valve job
-milled 0.003
-type r intake manifold
-skunk2 stage 1 cams
-skunk2 valvetrain
-str adj cam gears
-aem cold air intake
-FPR
-B18a bottom end
-bored out .50
-aftermarket oversized pr3 pistons
-polished journals
-new vtec bearings
-ARP rod bolts, head studs and main bolts
-gsr water pump
-gsr oil pump
-2 1/4 inch cat back exhaust
well Ihave stock headers on the car right now and I’m looking to spend a good amount of money (not toooooo much) and I’m looking for something that will improve the midrange to high end.
Comptech 4-2-1 is what i have way better than the old dc 4-2-1 , the primaries are alot bigger for more horsepower
JDM ITR header is a good option but kinda expensive and need modification to the xmember and cat but a very nice choice
JDM DC ITR OR GSR 4-1 are good options also but clearance can be a issue if your car is to low , and theres always the JUN<SPOON> ect headers very hefty price tag but perform
its up to you , my choice would be the comptech or jdm itr for that setup
