Which radiator hoses will fit on B18c1 head?
I searched and no solid answer. I read all the bottom hose are the same on b-series. I’m not sure how true that is. It’s time to change my coolant hoses before the track opens back up :excite: and I want to get the mishimoto set. Anyone has the 90-93 integra mishimoto kit on there B18c1 heads or the 94+ gsr set?
  1. all b series lower radiator hose is the SAME (DA bseries, DC b series)
  2. top radiator hose strickly is dependant on the HEAD you have because the water neck location is different between b16 & gsr head.
  3. get DC GSR spec radiator hose “set”… you’ll be fine.
Charlie
[QUOTE=charlie moua;2310010]1) all b series lower radiator hose is the SAME (DA bseries, DC b series)
2) top radiator hose strickly is dependant on the HEAD you have because the water neck location is different between b16 & gsr head.
3) get DC GSR spec radiator hose “set”… you’ll be fine.
Charlie[/QUOTE]
Thanks.
got the hose today and it fits perfect.
