Which Springs ASAP!!
Which springs are for the front and which are for the back?
1
2
the shorter springs usually go in the front; longer ones in the back.
from your pics i cant tell which is the shorter or the longer one
Damn I put them in… the back is hella ****in high… there is like a 3finger gap, and the front is slammed as ****… I think i’m gonna put my cut springs in the rear again.
from the pics i’d say the top pic is the rear spring and the bottom is the front spring. typically the rear springs have more of a gap in between each coil than do the fronts.
sounds to me like you put them in wrong. high in the back and low in the front is pretty much a sign that they are backwards (since the front springs are higher spring rate, and when put in the back it doesn’t lower much… and the rear springs are a softer spring rate, so when put in the fron the weight of the engine gives a huge drop).
well usually from drop springs… the rear is gonna look like its sitting lower cuz of the gaps
yep the ones that look progressive wound youd think go in the front, but they in fact go in the rear.
