Which starter to use?
I need to know which starter to use. Car is a 90 Integra with a 98 ls motor. The tranny is a 93 ls cable tranny. The car started out as an auto and we did a 5spd swap.
We tried cranking it last night and got no spark and the starter didnt work. we are unsure if the starters are even interchangable. Question is, what starter do we use?? will a 93 manual work or do we need one to match the motor? We currently just have the auto starter because this was a issue we were totally unsure of.
use a '90 starter. car is obd0 so use obd0 starter so you don’t have to do any rewiring or anything.
i’m using a '90 starter on my '99 b20z with obd1 conversion. It works fine.
I just checked part numbers to make sure I was giving you accurate info - '90 starter and '93 starter have different part #'s.
use 90-93 strater…should all be the same part number…
different part numbers according to all starters listed on partsamerica.com
yeah…your right…but all 90-93 starters should work…my brother had a crx with 1st gen B16 and B16 cable tranny, his starter went out and an LS one worked fine…so any LS starter within those years should work…
ok. so if we use a 90, even though we did do the obd1 conversion, it should still be good right?
I will try to buy a 90 today and hope for the best :slight_smile:
mugencivic4dr - i was thinking the same. however i wasnt sure they would be the same when it comes to automatic or manual.
i didnt even know the auto starters worked until you mentioned that you were using one…but i ment all 90-93 5spd starters…
but good luck and hope it works…
[QUOTE=mugencivic4dr;1824335]i didnt even know the auto starters worked until you mentioned that you were using one…but i ment all 90-93 5spd starters…
but good luck and hope it works…[/QUOTE]
i checked the part #'s on the '90 and the '93 both for manuals and they are different.
just get yourself a '90 5 speed started. I have an obd1 '90 5 speed starter on my '99 b20z with obd1 conversion and it works fine.
fin.
all beseries starters work
its just the terminal is diff location and little moving wont be hard
must be 5 speed if car is 5speed
ect
