i have spc upper ball joints on my 93 gst with a pretty aggressive drop. it feels as if im riding on the ball joints because even the smallest bump will cause my car to bottom out. has any one used any UCA’s that improve this issue? thanks
basically if your slammed no matter what you have, it will hit the shock towers. i have the spc +3 degrees ball joints and they’ve hit a couple times. only on really bad bumps though. the bump stops take the rest of the beating. full upper control arms are longer in length so they’ll hit the shock tower even more if im correct.
