i’ll have a b16 in my garage shortly and wanted to bump up comp. a little. hondamotorsonline.com sells ctr pistons with rings for 320$ 11.0:1 or shave the head and put a thinner copper h- gasket on it. both be around 11.0:1 but one involves taking the bottom end apart and the other just the top end. also i wanted to maybe get cams and gears . i 've seen a few setups with just a ctr intake cam and stock exh. cam is this a good street combo.
do the pistons dont mill the head man! ive heard some stories about bad things to milled heads! but its ur call!
hth
Compression
yeah dont mill the head, cause im sure it will retard your timing…but correct me if im wrong. go with the dofferent pistons and better cams to take advantage of your higher comp.
