White smoke after Skunk2 IM and TB install, please help
So this past saturday I installed my skunk2 intake manifold and throttle body with Blox throttle position sensor (TPS) and Blox thermal shield intake manifold gasket. I looped the coolant lines that previously went to the FITV and looped the extra vacuum lines. Starting it was hard to do, I had to play with the gas pedal a bit, as soon as it started there was white smoke coming out from the exhaust. CLOUDS of white smoke. I turned it off, checked everything… No leaks, it all looked ok. Started it and it started smoking again, I drove it home and now I need to figure out what I did wrong… You should probably know when I put the TPS on I tried to calibrate it to .85 ohms closed but I could not rotate it far enough to get the reading that low. Instead it was around 1.05-1.06. Is that bad? It seemed to run fine, except for the white smoke pouring out the exhaust… Pretty sure thats coolant. I need some advice and guidance please. Suggestions would be much appreciated!
your definitely getting coolant in the cylinder. only 3 places it could really come from in relation to the IM. thats the IM gasket, TB, or IACV. the last 2 dont really have a way to leak into the manifold which leaves your IM gasket.
Ok. I’m going to take it off and check out the gasket as soon as I get a chance. Thanks for the response.
