White smoke? What is it?
Okay when I drive my car, white smoke comes out of the exhaust and smells like acid, what could this be?
chronic
Do you have milky oil? Check it on the dip stick. If so your head gasket could be toast! Or you could have a cracked head. :danger: Not good.
aslo check to make sure your engine has the correct amt. of oil. one time a saw a guy put waaaay too much oil in his car and it started smokin real bad… check your batery for that acid smell. make sure it is not caracked and spilling fluid on something hot (making it smoke). or maybe somthing is stuck to your exh./piping. one time i got a plastic bag from a grocery store stuck on mine and it took a long time for the smell to go away…
~Andee
