guys i wanna now what problems do you have after instalation of LSVTEC, thats because i’ll go for the swap tomorrow and i want to know what problems usually the mod give to anybody, any info will aprecciate…
:search:
i made it two weeks ago and i still no have problems after instalation …
In the process of installation you got to check your oil line carefuly…
check for oil leaks around the new external oil line. Also check for this as well as other oil leaks after about 1k miles or so. thats the only thing I would inspect that you wouldnt normally inspect on any other motor. Anything that would be a problem with this conversion will usually jump out and stare you in the face once you turn her over ie piston slap, vtec not activating, check engine light, etc etc
