WHY Blank rotors are better than cross drilled and/or slotted
From Honda-Tech Forum posted by Redline96LX
http://honda-tech.com/zerothread?id=1437507
Ok I’m hearing a lot of conjecture, and people are STILL blowing money on ****ty rotors, so I will tell you all why blank rotors are better.
The reason for the creation of cross drilled rotors initially was to remove the “gasses” from the brake pads. HOWEVER, most of your modern brake pads (Axxis metal, AEM semi-ceramic) do NOT produce gasses when heating. This was on bad brake pads used in the 1950s and 1960s. Back then, asbestos was also used, and we dont use that either.
The other reason is so called heat dissapation. I don’t have my physics and thermo books with me, but the logic is that the holes in the rotor are suppose to allow the brake pad to cool. So…air gets into the rotor from the inside of the vents. If you have a back rotor which is solid, air gets into these holes how? If your stopped, you are leaving air inside these holes sandwiched between the pads, thus creating air with a rising temperature. Its increasing in pressure from the heat, which I guess you “could” call a gas that would affect braking. So the cross drilled rotors do not remove any gasses formed by brake pads (because there are none created anymore) but could possibly inhibit the creation of “hot spots”.
Cross drilled rotors have LESS contact area because of the holes.
But if the rotor is cooler, its better, right? Well no, because these rotors are not cooler. THe heat is generated from the pad/rotor contact. What removes heat the most effectively? When stopped or moving, the pad transfers heat into the rotor because its made of cast iron. the rotor has a lot of surface area and even vanes in it. But the little holes allow air in this surface contact, and you can transfer more heat into a solid big ass chunk of cast iron more than you can into the air. Don’t believe me? Touch some steam at 150 degrees, then touch a piece of hot metal which is at 150 degrees. Which burns your hand? the metal. So let the heat transfer into the metal, because since it has so much more surface area, dissapates better.
Safety!!
Cross drilled rotors can crack! I have seen them!!
Even racing teams will reccomend AGAINST cross drilled rotors:
http://www.livermoreperformanc…html
Companies that sell cross drilled rotors that are redrilled may not be structurally sound. I have actually seen pictures of rear Integra rotors that have had hairline cracks turn into the rotor actually breaking apart!
Do your homework. Even Porsche and Ferrari will admit that the cross drilled rotors they use are for looks. So if you are one of those kids who thinks the little holes look cool, get a name brand drilled rotor like Ferrari does. The REASON Ferrari’s ‘holed’ rotors are alright to use is because they are CAST with the holes in them, so they are not actually drilled into cast iron rotors. Cheap drilled rotors are not safe, and even the good ones are not necessary. Why do Ferrari do it? People THINK they want it, and it sells. If you don’t believe me, go into the business world. You will learn that pretty soon, you can sell utter **** if people THINK its better.
Information I gathered from http://www.pdm-racing.com/prod....html
says:
"KVR Crossdrilled Rotors
Why should you upgrade to cross drilled rotors?
Simply stated, the function of any vehicles brake system is to stop the vehicle. This is accomplished by absorbing the kinetic energy stored in the moving vehicle, and converting it into heat. The friction caused by the brake pad rubbing on the rotor is the source of this heat. The more quickly and efficiently that heat can be absorbed and dissipated, the more quickly and efficiently the car will stop.
There are several contributing factors to this heat reduction. One of the most common sources of heat is from the gases produced by the bonding agents of the brake pad burning off. Under severe braking, this can actually produce a boundary layer of gas that pushes the pad away from the rotor, which can lead to excessive brake fade. The cross-drilled holes or slots in a rotor provide an escape path for these gasses (de-gassing or out-gassing are common terms), and allow the pad to stay in contact with the rotor. As well as de-gassing, cross drilling or slotting will provide better wet weather braking as water is swept through the holes, or down the slots.
A vented rotor can be viewed as an air fan. When in motion, the vents draw air from the center of the rotor outward. This air flow, over an increased internal surface area, effectively dissipates rotor heat. Cross drilling adds to this air flow, as well as providing additional rotor surface cooling. "
This company is just telling you that the rotors may be cooler, however they fail to mention that the holes really do create a more than substantial decrease in surface area, thus less braking, thus less heat created, thus the less heat CREATED will leave the rotors cooler, the holes barely do anything! Its the less braking lowering the temperature!
Slotted rotors-
Find me a company that uses stock slotted rotors. They remove brake dust, but if you study braking systems, you find that with modern cars, flat blank rotors and semi-ceramic pads, the brake dust causing the rotor to slip on it is almost non-existent. But the brake dust doesnt need all those lines. Notice how most front brake pads (and most back) have that line down the middle to give essentially two bite points. If OEM or racing companies found it to be a benefit, they would do it.
PROOF OF IT ALL:
Find me an F1 car as of now that uses cross drilled or slotted rotors.
They all use full ceramic rotors and ceramic pads. Are they drilled or slotted? No.
If they helped the fastest cars in the world, wouldn’t they use them? Its basic calculations that show the lack in surface area does not make up for the possible loss in temperarure. They use brake cooling air ducts insted.
BIG BRAKE KITS:
Some have asked if the big brake kits are worth it. This is sort of a relative question, but the simple answer is no. Regarding the big ones with drilled rotors, if you know that they are cast that way, at least they wont crack. I will still advice against them.
In terms of a big brake kit, I have seen some for Civic DX models. Civics have the small pad, small caliper, and a 9.5" rotor. The big rotors are 12" in diameter, ok so the overall diameter is close to that of an Acura RL (1999). But the sweeping area (the area that the pad can grab) is still the same if they use the same caliper and same pad. If you have the same pad and caliper, you are using the same rotor surface, just farther out, so it will increase braking from stock. However, if you were to change knuckles, etc, and get Acura RL caliper (larger piston than your civic DX piston), RL pads (much bigger and taller), and RL rotors 11.8" but much more surface area is touched, then you have a better brake setup because you have OEM parts, and a better grip on more area of the rotor. The downfall is added weight (since big brake kits are usually 2 piece and lighter) but the benefit is that you have so much more stopping. Ok, so the big brake kit will have less unsprung and rotational mass (so a little better accelleration but less braking), but they tend to run over a grand, and you can use OEM parts to build a better setup for half that.
IN CONCLUSION:
Don’t buy slotted or cross drilled rotors, blank are better, and stop better. Physics people, get me my formulas and help me out here.
If you must get rotors with designs on them, get the slotted ones by a good company, and DON’T get blank rotors redrilled with little holes all over them. IF you absolutly must have the rotors with holes cause you like em, get them from a company that casts the rotors like that. I have seen rotors break and this is for your safety!
REMEMBER…
Your car will only stop as fast as your tires will allow. All the braking in the world wont work if your tires are bald and on ice!![/QUOTE]
Some decent bits of info here. I’ve been on Late Model race crews and those brake rotors will GLOW bright orange from the heat that gets generated. Guess what… we didn’t run slotted and/or cross drilled rotors. Just ran some vented blank disks with metallic/ceramic pads. Cross drilled and/or slotted rotors sure look cool though. :slight_smile:
Wilwood stopped using cross-drilled or slotted rotors because they had problems with thickness variation due to overheating (which some like to call warping). I had a friend who got a new set of front rotors for his WRX from Wilwood for free due to this problem.
…also, F1 cars are starting to experiment with carbon discs (yes, very much like CF). I know a guy on a test crew who’s got a pair in his basement.
For the most part, I’m pretty sure anyone who actually know’s what they are doing and still buys cross-drilled/slotted rotors are doing it on looks alone. Nevertheless, thanks for the info.
this was a very benificial bit of info. thanks for posting it. as for the added weight of the Legend setup compared to the aftermarket i’d go with the bettter braking. i base all of my driving on race techniques(we all know you don’t have to be racing to use these effectively to avoid the idiots on the highway). a driver can get around the track faster if he can brake later into a turn minimizing brake time allowing him to carry speed deeper into the corner. sure the acceleration is hit but much more minimally than the benifit of being able to get into the corner faster. end result, faster time around the track.
besides i’d like that assurance that when that person that decides to cut me off to slow down i can stop faster.
Very interesting!! :werd:
changing brake components usually changes feel and heat capacity, rather than a reduction of stopping distances.
if you can lock up your tires/engage ABS with your current brake setup, it means that your brakes are creating more force than the tires can generate grip. until your tires start to generate more grip than there is braking force, your stopping distances won’t change dramatically.
increasing the size of a brake rotor, and increasing the clamping force of the caliper, or increasing the coeff. of friction of the brake pads may increase the amount of tq a brake system can generate, but the fact of the matter is is that all you are doing are lessening the amount of pedal effort it takes to lock up the wheels.
The new BMW M5 that came in at my work had both drilled and slotted factory rotors. Man that was one sweet ride…
Monkey is right, tires stop your car, not your brakes. The tires are the only things in contact with the ground. To stop considerable faster (read shorter distances), get stickier or wider tires. For most of us, this is all that matters. For people whom autox or race, the constant braking will build up heat in the rotors, leading to brake fade. Most brake upgrades deal with the problems from brake fade, but 95% of the time a street car will not and should not see problems with this (exceptions are drive down a steep mountain or towing [yeah, right]). Also, obviously if the car is lighter there will be less mass to change direction and less torque will be needed.
thats allot of fuckin reading so i’ll just take your word for it
good thing i just ordered and recieved some oem blanks :smiley: got the pair for a very very good price
I have a full set of cross drilled/slotted rotors…and they do stop faster than before. I did a 40-0mph test with blanks and then drilled/slotted.
Did the guy in the article above think about the glaze the pads and rotors get…hmm…the slots keep the brakes from having the slick glaze on them after so long. But im no expert, I just did 40-0mph distance checks, but what do i know.
What pads are you using with those cross-drilled rotors? I’d be more interested in seeing what difference is made in a repeated heavy braking scenerio, such as an autocross. All reports I’ve read indicate that cross-drilled or slotted rotors don’t help with brake fade at all vs. blank rotors.
I just use stock OEM acura brakes, but then again, I dont do alot of heavy braking like in autocross. Most people buy them to stop faster and for image, not for constant braking scenarios like autocross.
I have them mainly because people in texas cant drive and switch lanes with no blinkers and not looking and its not a slow lane change either.
Also, if you put the rotors on backwards like I have seen alot of people do (which I just never tell them), then its just worthless and doesnt help, it just makes it worse…lol
anyways, im not a pro, so i could be totally wrong, but i just go by my brake test with normal everyday braking, not heavy duty
I am using powerslot rotors and hawk pads and the brakes grab ALOT better than they did stock. The pedal feels tight and brakes are VERY responsive, but the hawk pads dont last very long, about 8 months with about 10 runs at the 1/4 stopping from 106mph-25mph.
Not that I’m calling you a liar, but seat of the pants observations don’t do much for me. If you could explain HOW that would be cool.
I’ve heard that Hawks are ridiculous in their wear. Try the Reds…you’ll be surprised.
ive been rockin brembo blanks…just cuz they r cheaper priced too :smiley:
eh. I’ve got brembo blanks on my car, and they are getting replaced with Baer Decala’s.
I’ve got cross/drilled on my car, and braking is a lot better. In somones response above, it said that “tires stop your car, not your brakes”, I agree with that…but how hard do you have to push on your brake pedal for your car to slow down in the minimum amount of time without locking up your tires? From my old blank oem acura brakes to my newer cross/drilled, I only have to apply about 50% of the pressure to stop the equal amount as I did before. And I agree with another post above, cross/drilled don’t really get glazed like blanks do. There might be less surface on the rotors for the pads to come in contact with, but the slots keep your rotors from having that glazed buildup. I prefer cross/drilled, or at least slotted. My friend has slotted Powerstops on his gsr dc, and that car can brake like crazy. He’s got good tires too…but I’m sure that if he had oem blanks, he wouldn’t be stopping as quick. And as far as comparing our daily drivers to all those F1 cars and all the other racing cars, :wtf: are you thinking? How often do they change their pads and rotors? TOTALLY different setups than what we drive. I doubt anyone who has posted on this thread has a fully blown out race integra that only touches the track. :bang: Prove me wrong though.
