Is anyone running a 225/45/15 size tire on their DA? I’m trying to purchase some off this one person, but he thinks they will rub on my car, at full lock and turns. The wheels are 15x7 +38offset!
i have 215/40/16 on 16X7 drag DR16s and they dont rub. the size you are talking about will rub especially if you are lowered.
205/55/15 rubbed until i adjusted rear camber one turn below zero. Fronts were fine with no camber kit. I have a mild drop.
[QUOTE=scratchymaster;1690683]205/55/15 rubbed until i adjusted rear camber one turn below zero. Fronts were fine with no camber kit. I have a mild drop.[/QUOTE]you serious? what wheels? i’d been thinking of using that size on my fat fives, stock suspension…
Rota GT3’s. I traded tires to get them and got lucky that I got rid of the rub in one suspension tweak. Before the camber tweak, the very edge of the rear fender scribed a scratch all around the tire, right below the tread but not yet to the sidewall.
The car is at max ride height for Skunk2 coilovers, which is about an inch below stock?
