Wierd Clunk when I shift to 2nd
Hello,
When I go driving out in my teg I notice a “pull” “clunky” thing when I push the clutch in when i am going to shift to 2nd. Like I am in first at 2k-3k RPM when I push in the clutch cause it’s time to shift I notice the pull feeling, after that it’s fine. I don’t think it supposed to be like that am I maybe going to high in first when I shift? Am I maybe pushing the peddle in to slowly? To Fast?
Any help is apreciated,
Thanks Again :slight_smile:
2-3k rpm too high? no, thats not the problem… this happens juss when your going from 1st gear to 2nd? wierd… well i dont know,sorry but it aint revvin too high…if anything thats revvin too low… :stuck_out_tongue: and theres no such thing as pushing in the clutch too fast or too slow, u need to do both when driving… there mite a problem wit ur clutch…?
Sounds like ur still learning how to drive standard. Learn to drive first then see if its the clutch. Try letting the clutch out slow in second
It’s nothing wrong with your car… its your driving. (not a bad thing)
I get the same thing when i’m in 1st in stop and go traffic. I think the problem is your letting off the gas too soon before putting your foot into the clutch. Hence(sp?)… the car wants to rev down like it does when you down shift.
Try stepping on the clutch at the same time you let off the gas and see if that works.
HTH
You hit the nail on the head with that reply…
Next Time I go out I will definitly try pushing the clutch in sooner
