Has or is anyone using this product. 4 piston calipers and a 12+ inch rotor. The website indicates for 94-01 integs w/ 10.25" (262mm) OE rotors and 90-99 civic w/ 9.44" (240mm) OE rotors. Will either of these two kits work for our car types. I own a 93’ integ and want to upgrade to larger brakes. Thanks for your time.
http://www.precisionbrakescompany.com/wilwood_honda_brakes.html:confused:
FINALLY!!! Now we’re goin in the right direction. People think that just drilled or slotted rotors & pads can improve your stopping power. What a joke…THIS is what really improves braking.
XLR: You can try spoon calipers, wilwood isnt your only option.
I think you need larger rims to fit bigger calipers since stockers dont cut it.
spoon calipers also cost $1,800 where the Wilwood’s cost around $650 for 12" rotors and 4 piston calipers. Wilwood has been in business for 20+ years and are used in top fuel dragsters so you know they will stop on a dime. I just wish there was someone out there that could confirm whether or not they can be used on a 93’ integra???
Talk to member DB2-R81 … he has the Wilwood setup on his GS-R.
