My suspension component that runs parallel to the strut in the front drivers side is bent inward a little from an accident from the previous owner. I think this is called the control arm(?). This is causing my camber to be very bad. Will a control arm from a civic fit my integra? My friend who owns both a 91 civic 4dr and 94 Integra said the suspension components look identical, but was not sure if they were interchangeable. If anyone knows, please tell me…
i have a 90 civic si hb and a 90 integ ls i know for sure the rear is the same cuz i helped in the disc swap for the civic hb…but i can find out and let you know cuz i will be pullin the control arm out of my civic and installin es bushings so i will be able to compare…email me baldb0y429@aol.com
lower control arms are interchangable between ef and da… but they dont run parallel to the strut. might post a pic of what you need for a solid verification.
