will a 2dr dash fit ona 4dr
i have a 4dr and it has blue interior i want to switch it to black interior anyoune have the full black interior for sale and i have a black dash just wondering if itl fit b4 i take everything apart
yes it will fit
yes it will fit. just be careful upon disassembling your dash. there are some secret screws on the bracket that holds the stereo in, and one behind the clock, and two behind the defrost vents that connect into the door and a couple under the dash. make sure to remove the gauge cluster, radio…oh and everything!, all the plastic, shift knob, steering column bolts…takes about 2 hrs to pull a dash.
2 hrs??? 1 @ most. also there is a screw that holds the climate control. i would leave it on and not remove the controls cause the cables are a bitch to remove and you just might break it. just leave it there and it will be held up by the bracket thats behind it
true. sometimes it’s easier to drop the column, if you don’t have a steering wheel puller. just 4 bolts
took me 8 hrs to do a dash swap. I’m also nuts about putting every wire loom and clip exactly where it should go. Watch out for an attached ground that’s on the under right side below the cluster as well. A nice black dash is well worth it though. clip off the backside of the rivets on the vin rather than drilling them out, it works better.
i can take a dash put in about 35 min or so put one back about an hr or less have done it several times just never to a 4dr i found a mint black 1 so i wana swap it out and change it to the black anyone have black 4dr interior
