will dc springs fit my da stock struts
Well, I’ve look every were and figured I’d just ask so, I picked up a set of Eibach pro springs from my friend off of his dc for $35, so I couldn’t pass it up but I’m just wondering if they will fit my stock struts because, I’ve been reading that dc struts are fatter then stock da. Could anyone help me out with this any other info would be awesome too thanks. Joe
yes
Well what about the 2 1/2 inch difference of the rear Da strut compaired to the DC, is this going to effect the ride any? The springs i bought only give a 1.3" drop front and back so that’s almost 4" drop if i’m not mistaken for the back. i’m worried that my car will sit lower in the back.
yeah i think it would, cuz before i bought my suspension i dropped some DC Nuespeed race springs and the back was dropped like hell. but it rode pretty smooth
So your saying that the back is going to be lower? Or just as slammed as the front.
backs gonna be lower but hey i could be wrong dude only one way to find out is to try it… not that hard
Originally Posted by whoa its len 2
Will DC2 springs that drop 2" lower a DA 2" also? Any offset in drop between the two setups? Im leaning towards a neuspeed/h&r race setup and dont want any uneveness in lowering if I do the DC2 conversion.
I’m running ITR H&R Road race coilovers and they are almost at the highest threads to make my car a reasonable height…so, no…2" advertised drop on a DC does not = 2" drop on a DA with DC forks.
from another thread I found searching. Your ride height won’t be what it would on a DC. Everyone I’ve seen using DC suspension on their DA runs DC forks and DC coilovers. That way you can adjust for the difference.
front springs i believer are fatter than the da’s
so fronts might not work.
i might be wrong just something i heard somewhere.
I would not recommend it. The rear will sit much lower and I don’t know that the front ones will even fit (DC front and rear springs are the same diameter as the DA rear springs). If they are an adjustable coilover setup, that might work just fine.
Well i got the springs and there all the same height so i’m thinking they will drop the car evin and all fit but, I’ll let you guys know in a few days i’m currently letting my new paint job harden more just got sprayed yesterday :rockon:
The two with the most or tightest coils are for the front and the two with the least coils are for the rear (higher spring rate in the front). The front ones may even be slightly taller than the rear. I still don’t think the front ones will fit. I’ve had both sitting side by side.
i have a complete DC suspension lookin at right now and the back assembly is taller… but thats probbaly because the front forks arnt on the front assembly
^I’m talking about spring length, not strut length.
