Will these pistons fit
Fit what? I hope you’ve done a little more searching for a better price. Inline Four or JDM Hondaparts
sorry will they fit a b19a block (i have to think before i type)
b18a sorry i have to learn type also
Yes they’ll fit but will give you a lot higher compression in your b18 than you may think. The 10.8:1 comp they claim is probably for a b16a or b but in a b18 you’ll have closer to 12:1. You should buy leftcorner’s integra type-r pistons for a more reasonable compression ratio.
This is going to sound stupid but i reley don’t understand compression rates what is the difference between 10:1 and 12:1 in do if i want to go fast then what do i want high compresion or low i was under the impression that you want a high one or is a high one bad
too high of compression will cause detonation unless you have very very high octane gas. you can also run into clearance issues where the valves will hit the pistons, which is a bad thing
to low of compression is also bad. it wont hurt the motor(that i know of), but you wont get any power. i would say, just get some aftermarket pistons made for your engine, that way you will be safe.![]()
huh?
12:1?
I dont think so. LS head has larger chamber at 45cc vs. b18c1 at 41.7cc and b16a at 42.6cc.
larger area = lowered CR
