I need to know ASAP if Type r gearing will fit in cable transmission and lsd thanks
Yes, b series hydro gearing will fit into a YS1 cable case - but it will not fit into an S1/Y1/A1/J1 cable case. Also, in order to fit the hydro gears (or the lsd, I forget which is the issue) there is some grinding you need to do on the inside of the case to gain clearance.
Oh ok thank you buddy
To fit the lsd dif you have to grind down some of the internal casting Web.
