wilwood big brake
hello i just bought a 1993 da9 ls special and it has the wilwood big brake set up but i cant fit these 16s i bought can i just use the wilwood caliper and remove the rotor to the stock
This isnt the correct forum, you want suspension, brakes and wheels.
That being said, you cant just switch the rotors, the caliper bracket for the wilwoods is made for that size rotor, and the caliper will not bolt up to a stock bracket.
Does it not clear the 16’s, or does it rub the inside of the spokes when you put the wheel on? I thought the wilwood bbk did fit 16’s. You might just have an offset issue, and need spacers.
yes i just figured it out i did post it on that section sorry
No, you cant just put oem size rotors on there. You might have to space your wheels if its not a diameter issue. If you wanna run those wheels that bad without spacing them just go back to oem brakes and sell those.
