ok so here’s the original post,
Ok so i was having trouble with my POWER driver side window a few months back, it wasnt rolling up or down, so then after a while it started working on it’s own for like 5 months it worked.
I always had to pull it up and push it down while rolling it because it was get stuck and i’d hear the grinding from the motor i believe. I dont think it’s the switch box, i bought a new one…and i removed the dust from the old one.
The key words here are…
The rotational grinding…when that happens it feels as if the window wasnt connected to the regulator so i’d push down a lil and it would continue to go down. Same thing with going up, i’d have to help pull it up but the motor would do the rest…
Can anyone tell me if it’s the motor or not? I grounded it but still no power…it went out yesterday.
I think its the motor but i wanna be sure before i go drop Dime on something i dont need…
Lemme know guys…
it’s a 93 integra rs sedan
UPDATE
So anyways i went to the junkyard bought another motor and regulator. I assume the regulator is the metal rails connected to the motor, I hooked them up and the motor still isnt running, i tried running and heat and ground to it and no luck, the motor will not go…
Anyone know what it could be…Relay or bad fuse? it’s gotta be one or the other right, cuz i mean the motor is good…i just wasted 22 bucks on a second one that’s my fault, what you guys think…you guys always hook it up and give me insight, that’s why i come to you. thanks, please me let know, i needa get this fixed before this weekend is over so when i go to school no one breaks into my car, thanks…
