window motor going out?
After months of dealing with it, I finally adjusted my passenger window so it pops underneath the weatherstripping every time. Another problem I had, which I couldn’t see a solution to, was that the (power) window rolls very slow in the middle of the travel. It rolls fast when it’s close to all the way up or down, but noticeably slower in the middle. Is the motor starting to give up, or is there something I can do?
http://www.g2ic.com/forums/showthread.php?t=169915&highlight=window+slow
Check that out. It should take you through step-by-step on how to fix the slow-rolling problem. I don’t see how it could be the motor if it rolls fine other times. Good luck!
Thanks for the link. I’ll try it out when I can.
