ive look everywhere but cant find how to take apart the door to get to the window motor.
my passenger side window is stuck up and i need to fix it asap. summer is here already and its gonna be hot. i do have a/c but i do like the windows to be down sometime to. pics of the process will be great.
Are you sure it is the window motor that is bad. have you checked it?
Have you checked fuse 2 - 20A, [hot in run] in under dash fuse box?
Have you checked for power at both the drivers side pass. and pass. side switch, [blue/black lead at switch].
Have you checked the switches themselves, bad window switches are common on G2s.
There is a lot of simple testing to do before you spend the time and effort to remove the window regulators and swap the motors, a real PITA, even bigger if you do the swap only to find out it was not the motor in the first place.
