window problem. searched.
ok so its been like a week since my driver side window stopped working. its not the switch or the motor. i can get it go down half way, then it wont come back up, i can even pull or push it down or up. i hear the motor running but its like the gears arent catching. ive pulled apart the door panel, and the thin plastic but i cant see the problem. is it a quick fix like adjusting a bolt? i searched and all the other window problems were either switches or fuses.
no body knows??
window regulator wore out that why you can push it down an pull it up
how can i fix it then?
RTFM:gtfo:
replace the window reg (it the piece the window on)
