I cleaned the switches, the passengers side works a bit better, the drivers side still does not work at all. how do you test the wiring, and how do you test the motor???
a multimeter would help a lot for testing out the wiring.
hook up the motor directly to a battery to see if it runs.
How do you test for continuity on the wires?
if u got a teg book, it should show you how.
use voltmeter or test12v to see if current is being outputted from the power window switches, all the way to the motor itself.
and again, test the motor w/ a bat and see if its the motor or the switch. although probably the switch if you say pass works.
