even in compatibility mode; by right clicking the program > properties> compatibility> cluck run this program in compatibility…?
hmmm. i’d try to check off “run this program as an admin” too. also, maybe try a usb connection that hasn’t been used by something else? i dunno. good luck!
only reason i am commenting on this is because i had a similar problem way back in the day when i was hacking cellphones with windows 2000. it would not see my usb devices unless i used a free port that had the correct baud rate on it and was running in windows 98 compatibility mode. good luck!
im considering buying a pro license but if i buy one i dont want the same probs but i dont realy want to spend the money for the pro license. however crome doesnt have a prob its only when u use the plugin
having the same issues with cromefree and freelog…can get freelog to read some data-vac/boost is dead on, not sure about how accurate other readings are but it shows a bunch.
also how do you setup the target lambda tables?? tried forever, i read you can update it but i can’t find a table to download…
i just can’t get anything other than logworks to log my a/f…i only really need something to log rpms and a/f together… i’ve been tuning the last 2 days by “good guessing”, though i only had a few major rich/lean spots to work out. i just watched my a/f, documented when i was lean/rich according to my rpm and vac/boost, and adjusted a few sections and much better. was hitting 10.4’s and 13.2’s now mainly between 11.0 and 12.5.
so i’m getting the hang of it the hard way, someone make my life easier…i would buy cromepro but if others can do this for free why can’t i??? gonna try running freelog as administrator(i have shitty vista) and i also know i need to switch my analog wires, have the yellow hooked up and i’ve been reading i need the brown wired in while tuning!! maybe this’ll help but…
