wats up guys im in the middle of putting my dash in and the wire harness is all set just got to plug in a couple more clips … ok my questions is (are) , i have a harness from a 93 integra does this harness carry more clips and plugs?? cause i see extra pink and other clips that i didnt see on my other harness…second there is a sensor above the brake pedal and i cant seem to find the clip anyone know the color of that clip and third is wat is this wire for on both of the harness i got the wire is broken at the end … i know its a ground wire but wat is it for >
pink is abs that ground wire goes in the area the radio is just put on a new end
ooo alrite cool …wat about the one on the brake pedal ? anyone
Brake? clutch has two one is to start it other is for cruise control
ok my car was having the same problem with the harness i just installed. everytime i went to put on the termials the battery would start to smoke like crazy so i just went out and bought a brand new battery and my problem was fixed??wth /?
now for my wire harness everything is basically alset but there are two things i need help with first is my brake lights …there is a sensor on the brake pedal which i mentioned but i cant find the clip could it be that the harness from the 93 dont have it ?
and my hazard lights dont work the blinkers do tho? is there a relay somewhere
and another thing there is a clip with two wires (purple, and black) near the kick panel anyone know wera that goes
