wire tuck problems, plz help!
Ok I have a 91 integra. First time doing a wire tuck. Did some research but some problems occurred lol the alternator won’t charge the battery and the battery light is on. Bought a new alternator and a battery and that didn’t help. Marked all the wires I had to cut and put them back exact. Any suggestions? Post on here or you can txt me at 605 323 5146 or if you got blackberry messenger pin is 326C9A87 need help asap please thanks!
Did you relocate the fuse box from the pass side shock tower? If so did you hook up the battery and alternator on their appropriate junction.
^^^^ this is a good question and to me sounds like it could be your problem
i’ll have to check that!! thanks…if thats not it idk what it could be. i rewired it all again and it still does the same thing :frowning:
