FCM need your help again =)
i did a full wire tuck on my car. fuse box is inside. battery also. all the good stuff.
When we tried cranking it, there was a clicking sound, but no cranking. Found out that the starter relay was not plugged in (the one on the right side of the A/C vent). My buddies and I tried bench starting the starter, and it caused the cluster to smoke.
So far we found all good fuses, but a burnt cluster, burnt main fuel relay, and burnt blinker (timed) relay.
I was told the fuse box might not be grounded correctly, its under my dash on the passenger side. Any advice on this?
P.S. before we tried cranking, everything worked on Ignition I, headlights, turn signals, horn, fuel pump was clicking, etc. After we cranked it (without the starter relay plugged in) everything besides the headlights stopped working on Ignition I.
thnx in advanced fcm =)
