does anyone have the pin out of the ob0 ecu so i could double check the connections also I want to know how to hook up the 02 4 wire sensor
long story short my main wire harness took a fat dump there was a lot of shorts by the driver side firewall that
in case you are wondering
{were not visible but I knew they where there engine temp gauge spiking to hot oil pressure light coming on and then the engine would bog and shut off turn on the lights temp gauge spikes oil light oil light illuminates and bogs down shuts off}
I got a used main wire harness from a 1991 it was the only one i could come up with it was perfect no after market alarm absolutely no hacking whats so ever
but it is ob0 so I bought the obo to ob1 jumper harness for the ob1 ecu the and a jumper harness so i could put the ob1 distributor and run that instead the problem
I was wondering can i run the car with no o2 sensor to see if it runs
