wobbling noise while driving...
normal driving…i hear wobbling noise…like my lug nuts are loose…but they arent…do tires with bad camber wear make noise??? thanks
It could be a wheel bearing going bad. Does it get worse while you are cornering??
Later,
BR
cornering is fine tho…i just got a new axle a month ago…could it be? i wonder what it is…
It could be the axle. You would have to take it off and put another one on to find out though…
Later,
BR
my car was still running fine even with my axle making noises when turning…now i got my broken axles changed, my car dont run as good as b4…hmmm what axle u using??? i got a rebuilt.thanks
I just put in some rebuilt ones not too long ago. Luckily, both of mine ended up alright but sometimes you get one that wasnt rebuilt right or that may have a bad cv joint.
Later,
BR
thanks BR…im gonna take my car to the shop and get it checked…thanks for the ideas
No problem, good luck with the fix…
Later,
BR
