wont crank over
im having problems with my integra put a 1999 ls in it but it wont crank over did the timing and changed the §§§§§ cap rotor ignition coil the igniter and im still not getting no spark would could be the problem? need help
won’t crank over or will crank over?
How did you test for spark?
More info…
MM&Y of the car?
When you say, “wont crank over” do you mean the starter is not working, engine not turning over, [cranking] or do you mean engine will not start, starter is working, engine turns over but will not fire, [start]? 92
since he says he’s not getting spark, i’d assume the engine does crank.
try checking for 12v keyed power at the black/yellow tracer wire of the distributor connector. use a test light
got it workin §§§§§ was bad but its keeps revin between 2 and three up and down how do i fix that
may be the map sensor, or the fitv needs a new valve cap…
you need to be a little more specific in your posts. 2 and 3 what? hundred? thousand? this is assuming your talking about rpm???
