Won't go in reverse!
So I just swapped out my tranny for another one now my reverse won’t go in 1-5 is fine but when I shift it into reverse itll grind and it sounds like it’s in place but
Gears don’t grab
Anyone???
so u just replaced the transmission?.. more than likely u have a bad tranny with no reverse… especially if you got a used tranny… the sad truth is that cable trannys are old… were 2011 so the average 90-93 transmission is 19-21 years old… and chances are that most trannys have never been rebuilt period and its very common to find a cable trans with problems. all i can say is make sure you have enough tranny fluid in the trans… other than that, their is nothing that you could of possibly connected wrong to stop the reverse from working… if it goes into gears 1-5 then obviously the shift linkage is working properly and its a problem inside the tranny… which means its out of you’re hands… good luck and keep us posted.
Its actually a gsr tranny I had a hasport conversion to cable and the casing was opened to see if it was a gsr tranny. But after I put the casing back on and threw everything bak on the reverse don’t work . I think I have a bad pin inside for the gear selector
