?wont start due to?
Im guessing when youj have all the buttons on the dash your car wont start? i have my dash apart right now to paint the interior and wanted to move it but seems like the ignition wont turn
Not sure what you mean “Im guessing when youj have all the buttons on the dash your car wont start?” what buttons??
If the ign. key will not turn I would guess you have an automatic transmission and the A/T gear position switch is out of alignment, try starting in neutral, you may need to move shifter around in the neutral spot to unlock the ign. switch.94
No its standard and i got it to start i dont know what it was but it fixed itself lol.
As handy as that would be it is unlikely it fixed itself, a better bet is you have an intermittent problem that could happen again at any time.
The other possibility is that the steering wheel was torqued left or right real tight and the steering wheel lock was preventing the key from turning, if it happens again move the steering wheel while turning the key. 94
