I recently order a new radiator from radiatordoctor on ebay and they sent me the wrong on they sent me one for an automatic so it has two open tubes or connectors on it. I need a radiator asap and it will probably be two weeks befor I can get another from them.
I was wondering if there was a way to plug the extra holes or run a hose from one to the other. to make it work w/ my manual.
Most aftermartket radiators have those two tubes at the bottom. It will fit in your car. Might need to bend up the tubes a little bit. Fill up that radiator halfway with water and see if the water drains out from those tubes, Im pretty sure they are already plugged. If not just get some hose and connect them together and you should be fine.
yeah those tubes are to cool the auto tranny. It will work for your car. You can plug or cover those tubes if you’re worried something might get in there.
