Hey guys, newbie here.
I am installing XM Radio in my wifes Integra. What is the best way to run the antenna wire around the rear window. Should I go over the rubber window surround and keep it on the window side or just stay on the car side of the surround.
Any help would be greatly appreciated.
i took out my rear washer and ran it directly into the car then stuck the antenna on top ofthe hole been this way for a year and has not leaked but is not a very easy install, you can also put it in your back deck this is what i did in my 93 prelude works great and was an easy install.
Bobo, you have the antenna inside the Prelude and it works fine. Hmm. I had thought about just sticking it to the inside of the trunk or something like this, but if it works fine just on the package tray, (where the rear speakers mount) I may just do this. I am correct in thinking that is what you meant by back deck.
LOL im pretty sure BOBO is a coworker of mine. If so lemme know next time you work. and yeah his works fine. and ging through the washer spot worked great and looked great. definately the easiest way to do it.
