Y1 lsd differential is shot.
ok so it seems like my lsd differential is shot since my car doesnt move while in gear at 2k rpms and when i rev the engine the miles go up with the rpm. I already checked the clutch cable and and had the clutch, pressure plate and fly wheel looked at by the clutch shop i bought it from…
Ive ruled everything out but the differential with facts so I took the 2 month old tranny back to the shop that rebuilt it so they can look into it. I have a big feeling its my lsd differential so is there any way to rebuild it or am i going to have to get a new or used b series diff?
Most likely the damage is pretty bad if you can’t drive it. As far as I know, honda does not provide individual replacement parts for lsd’s (only whole assemblies). So you will probably not be able to rebuild it.
You can use any b-series differential (lsd or not) so long as it matches your final drive.
[QUOTE=wise_old_dragon;2175050]Most likely the damage is pretty bad if you can’t drive it. As far as I know, honda does not provide individual replacement parts for lsd’s (only whole assemblies). So you will probably not be able to rebuild it.
You can use any b-series differential (lsd or not) so long as it matches your final drive.[/QUOTE]
yeah but I was trying to stick with the y1 b16 since it has really short gears and helps keep the rpms in vtec all the time durring shifting. Another B series cable tranny wont due since the gears are to long from a ys1 or even a gsr type. Ive looked up the gears and the jdm y1 is still shorter.
I do have a LS 5th in you guys are thinking my mpg sucks on the highway :wave:.
So wanting to keep my setup cable really rules out the gsr hydro tranny for now.
I think my only chance is buildign my tranny until every week point is bullet proof.
just get a obx or m factory and call it a day. i dont even think it matters if you have the ls final cause you can use those lsds for each type of tranny should be the same model for the ls or ys1 cable trans just do a lil more research and take your pick. good luck
[QUOTE=da6xsi06;2175374]yeah but I was trying to stick with the y1 b16 since it has really short gears and helps keep the rpms in vtec all the time durring shifting. Another B series cable tranny wont due since the gears are to long from a ys1 or even a gsr type. Ive looked up the gears and the jdm y1 is still shorter.
I think my only chance is buildign my tranny until every week point is bullet proof.[/QUOTE]
Sorry I guess It wasnt clear that I meant, You can’t rebuild the LSD (You can rebuild the tranny of course). You can still however put in another differential from another tranny (or aftermarket), thus reusing all of your gears.
oh ok I get you and, I kinda figured that out on my own since i didnt really want to go with another used eom lsd. I got online and searched high and low and found a brand spanking new Wavetrac lsd for my y1 b16 tranny and after i verifide the part number and other paper work I dropped it off at the shop and have them give my tranny a new heart… Ive heard the wavetrac is good for street and drag and the occacianal autox ect. this thing is supposed to outlast my tranny and the best part is I can drop it in another cable tranny wether its a b16 or LS.
