Y1 lsd passanger axle leak
Ok so I have a jdm Y1 with lsd and it has been rebuilt this last saturday with new seals and gaskets from honda and its leaking from the passanger side. Im tired of having this tranny leak all the time leaving spots after spots.
Im useing the 91 ls axles with abs, am I supposed to use the 92-93 gsr axle since the Y1 lsd is a gsr diff. Its leaking from the axle seal and I noticed that it has a bit of play so Im thinking the ls axles are a bit smaller than the gsr…
anyone out there with the jdm Y1 have the passanger side leaking also…
to give you guys an idea of my setup and help narrow it down:
innovative mounts for the 91 cable setup.(all 4)
skunk2 type s pro full coilovers. maybe a 1.5" drop its not slamed.
195-55-15 tires and still dont rub…
ingals front camber kit, nothing in the rear.
autozone 90-93 axles. I gave up on oem honda axles since it still leaked with them.
common I know theres people out there with jdm Y1 trannys. I just want to know if your having the same issue or not. I need help to isolate the probleme and figure out if maybe I have a bent lower control arm or something.
common guys Ive spent over $2k on the tranny with different shops, I need an Idea of what could cause the leak.
If anyone out there has a jdm Y1 let me know if you have the same issue, if not then let me know what axles you have…
Same setup without the LSD - Y1 diff, 90 -93 standard axles with play but no leaks Gofigure!
well my 2nd sir lsd just snaped in two after installing it 7 days ago, this time around im going to run a open diff since Im going to save up for a type r tranny.
Im also going to change to lower control arm incase it may be bent. Ill keep this thread posted by thursday see if im still leaking or not. I just need to pin point exactly whats causing the leak if it was the lsd diff’s or the lower control arm.
The axles should be the same, LSD or not. If you’re having a leak Id say either the seal was installed incorrectly, or you have something misaligned.
well today I finally got the tranny back and installed from my buddies shop. No more lsd for me, Im running a open diff and I did replace the passanger lower control arm. So far I took it out for a quick spin and no visable leaks afterwards, Ill check it again after work tomarrow. I hope my issue was bad lsd diffs or my lower control arm.
I keep hearing people say that Im running to wrong axles and Im supposed to use gsr or b16. I dont think they know much about the DAs other wise theyde know my car isnt a bseries swap, DAs come with B everything.
Yup. I’m running oem DA axles on my JDM trans and have zero leaks.
